Whirlpool icemaker not filling with water
jeffhej@hotmail.com
Model:  ED5VHEXVB01.  The icemaker isn't filling with ice.  I replaced the icemaker, the water filter, the intake water valve.  Still no water in ice maker.  I can't see an ice dam in the hose leading to the icemaker.  Any ideas?
  • jeffhej@hotmail.com
  • 16345Ed
jeffhej@hotmail.com
Forgot to add some things--The water dispense on the fridge is working fine, seems to fill quick enough, no problem with pressure.  The hose leading from the water inlet valve to the icemaker is not blocked.  I just took it off and blew air thru it.  The freezer is set on max cold and things in it seem cold enough to me.
How cold is freezer?
Youve changed everything. Hopefully you used OEM parts and not knock offs from Amazon
