hello i am new to this site i would like to know if above model main board takes slow blow fuse because everytime i put new fuse when compressor starts its blowing thanks
  • sampk
  • Vance R
Don't think it is a slow blow fuse. Disconnect all ac loads,  replace the fuse and plug the refrig back in to wall. If the fuse blow it is something on the board. If the fuse stays good, unplug the refrig and connect one load and plug in refrig. repeat this method to find out which load is blowing the fuse. The check that load for problems.
thanks it is bad compressor need new compressor may be new fridge
