thomassteen
Hi
My Miele G5985 is throwing F78 (circulation pump) shortly after start. It may run a minute or so. But then I get the error .
I exhanged the circulation pump for a used one. Same error.
I exchanged the electronics for a used one. Same error.
I am thinking that the used parts (or least one of them) has the same issue as the ones I removed from the DW.
I have measured the voltage level to the pump, measured at the electronics. I see from the service manual that one pin should be 15v, but I measured 13v. Not sure if this is the issue?
Can someone please send me the diagram? (I have the service manual ). Any advice is much appreciated.
  • 1 year later...
  • Replies 1
  • remedy510
  • thomassteen
What was the resolution on this?
