Kenmore 796.40311900 Clothes Washer LE Error Code
I have a Kenmore 796.40311900 upright Clothes Washer.  Of course, the moment my wife is out of town and I do a load it gets an LE error code.  I take off the back cover and realize that the Washer Rotor Assembly (4413ER1003B) splines are in bad shape and it appears to be slipping.  I did some research and realize that it could also be the Position Sensor (6501KW2002A).  I got a new Rotor Assembly and Sensor and put them both in.  It spins freely by hand and makes no noises, but when I start it up it makes a slapping/grinding noise like something is hitting and I get the LE error code again.
I look all around and can't figure it out.  So, I decide to get a new motor stator (4417EA1002K).  Again, I put it all together, its spins freely by hand but the moment it starts spinning it makes the noise like somethings hitting and I get the error code.
I feel like I replaced everything that could be causing the error code, but it still won't work.  Any ideas on what I'm missing?  Any help would be appreciated.
  • Vance R
  • jlcoj
  • Calebsil80
The wire harness from the position sensor to the connector on the frame is prone to wire breaking inside the insulation.
  • 2 years later...
ever solve this? encountering same issue but motor harness is good>
