precision1971 Posted July 21, 2020 Posted July 21, 2020 Manufacturer: ge Type of Appliance: FDBM fridge Model Number: pfss2mjxass Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes Hi I'm working on this GE FDBM fridge that is feezing in the lower fresh food area and the icemaker is overflowing. The water valve is pulsing a little bit of water into the icemaker with each door closure. I seem to remember the water valve should stop pulsing on when the fridge temp is satisfied. Not sure. Don't know where to begin and would like to go back with a service manual for proper diagnostics. Thanks
Captain Dunsel Posted July 21, 2020 Posted July 21, 2020 you should be able to uses this service manual. This is the mini manual. 1
Dave0361 Posted August 19, 2021 Posted August 19, 2021 Did you ever find a solution to this problem ? I have the same issue right now. Suspected bad ice maker but its not.
