I found bad board (solder joint melted)  and replaced but still no fans or compressor? Not sure where to go from here?
  • Jim H
  • Jedi Appliance Guy
Update. If I run temp controls all the way down everything comes on thinking encoder board WR55x1095. Where can I find this board.
Was the original complaint, everything was running except for the compressor?
Did you read the instructions that came with your replacement board carefully?
Did you keep the original board?
