drain pump rattling not working hanseatic wqp6-3602e
hi
Following problem I have a hanseatic wqp6-3602e desktop dishwasher. When I got it was already broken because the drain pump was not working just rattling. i was told maybe its because the pump is 50 hz but I live now in the phillipines with 60hz. Pump is a psb-01. Ok took it appart. Connected pump directly to power it worked flawless. Put it back in filled the machine with water, except the salt container, as I realized later. worked flawless. Put Salt and water in Salt container. Now when I tried the machine again. Same rattling sound. Machine does not pump. Maybe some more info to add. Machine seems to not have a water level sensor. So drain pump starts also when machine is dry. I ordered a new pump cheap. Hoping that helps. But until it arrives you have any suggestions?
thanks a lot
Felix ;-)
  • Replies 0
  • felix
