Hi there looking for some help as I’m running out of ideas. Had a thunderstorm and power outage in Toronto last week that knocked out our ac and shortly after our 4 year old ge cafe French door fridge (cfcp1rkbdss) stopped cooling the fridge and freezer. We’ve had daytime weather temps in the high 90s and even 100s lately.
I’ve tried changing the inverter board and main board but no luck. The condenser fan appears to be running.
lights are on inside The fridge and there is very faint air movement inside the fridge area but compressor refuses to run.
next step I’m thinking is to check the compressor terminals for resistance. Believe it should be about 6ohms across all three compressor nodes.
This is my first time attempting to fix a fridge and I made the pricey rookie mistake of replacing the boards before checking continuity for myself with a Multimeter.
if the compressor resistance is off I guess replacing the fridge makes sense? Anything else I can try?
thx in advance
  • Replies 0
  • Squeeks786
