Model FGMV175QFA. Frigidaire gallery.Unit went from tripping the breaker to not starting at all. I replaced a bad monitor switch (it was def stuck) and it still wouldn't start. I double checked the new switch and it was opening closing fine, but when I checked it with the harness on it had continuity both open and closed. The tech sheet wasn't much help to me b/c I still dont see how there could be constant continuity on that harness--even if the power relay was stuck (its on the monitor switch circuit)-- but... Im pretty wiped out this evening so I wouldnt put it past me lol. Btw, it was a universal 3 prong switch but the harness is goof proof in case you're minds headed that way...
I would greatly appreciate feedback as my customer is antsy for a solution. Thanks!
Jared
AmeriTech
There's a service bulletin for this:
FWIW, I always replace all the door switches as a set if the fuse has blown. It saves callbacks.
Edited by Terry Carmen
Thanks Terry, unfortunately my membership is expired and I'm not able to open the flash (pinching pennies atm). Ya, that's prob best, although the primary and secondary CHECKED good... But strangely the fuse wasnt blown.
What does the flash say is the problem? Bad board? Thanks.
Google "CK1903 electrolux" there are a few copies kicking around.
There are a bunch of parts they say to replace. I can't imagine it's actually cost effective.
  • 2 weeks later...
Well, apparently the customer thought so... Declined estimate. i can't blame them. Thanks for the help Terry!
