Rob Gabbard
Manufacturer: Fisher & Paykel
Type of Appliance: Washer
Model Number: WA37T26EW2
Customer reporting no spin, doesn’t complete cycle, and also clothes are coming out dirtier than they go in. Some type of sludge. Thanks in advance for any help!
Uploading what I believe to be your service manual.Waiting on approval.
Thanks, Captain!
Likely contenders being 11 years old
needs new suspension rods , they are prob bouncy as a pogo stick
remove inner bowl and clean out all the scrud
Rob Gabbard
I was leaning that way as well after a few videos I’ve seen and the scud section in the manual. Thanks for the heads up!
It’s also possible the drain pump is overheating and cutting out during the spin
this will cause during spin to stir up all the scrud onto the clothes
Rob Gabbard
After putting the washer in service mode and finding error code 40 Bowl Disengage, I noticed the drain pump only runs for a few seconds at a time even though it is getting a constant 120volts from the control. I'll be ordering a new drain pump. Thanks for all the help!
