I want to test my range oven's temperature sensor, but I can't get the connector / terminals out.  Need to know how to disconnect the sensor for testing.
I have removed the rack support, and loosened the sensor.  I can pull it into the oven as far as the end of the insulation, but it will not pull out any farther.  All the manuals I've read say to be careful not to pull too hard, move the insulation around, etc., but I am not able to get it to budge any farther.  Are there any tricks to loosen the wire or is there a connector somewhere else in this oven that I need to get to?
  • Replies 1
  • robnw
  • 16345Ed
Probably going to need to go from back. Remove back panel(s) to access connector.
But you should be able to  test it from control board.
