Samsung DV42H5400 Heater not working - heater relay not operating
Power good 120V on each leg.
When unit is running can measure 240V across both terminals of heater relay, tells me relay is not operating.
All t-stats 1-3 good, thermistor good at approximately 10KΩ, heater at 9.8Ω
Control board was replaced and new board has same symptoms with relay.
when I ran the smart install mode  the touch sensors worked  fine and then the check motor/heater test resulted in both operating fine result was OK. The heater worked fine for this test.
I suspect there may be a problem with the other boards.
Is there something I'm missing? Any help would be appreciated
  • Replies 0
  • Tonto61
