Viking VDSC4856GSS Double Oven Warming Issue
Hello,
I am dealing with the larger of the ovens. Just recently when we went to use the bake cycle, a large pop occurred and blew out the circuit breaker. Noticed a large black burn mark on it, so I replaced the 8 selector control and at the same time replaced the relay at the base of the stove. Now I can turn on the oven, but just gets luke warm. From what I can see the only other part that can be a issue is the Pre Heat Board Part Pe070308. Before I buy one to replace, is there anything else that possibly could cause the oven just to luke warm. The smaller oven works just fine, so I am just guessing the Pre Heat board has two circuits.
Thank you for your time.
JR
  • 4 years later...
  • Replies 1
  • gaspower
  • Corno Gobbo
I’m having a similar issue…did you end up resolving the problem?
