I have a Thermador PGR36GL - I had a power surge that burned out the control board (980-102-05) - A visual inspection found burn circuit board traces. The symptoms of the burned-up board are
-          Thermostat needle goes to 500 degrees
-          Oven and oven fan turn on
-          I hear the igniter and gas ignite
-          Turns off after 30 seconds
-          Blinking blue light 1-1
-           Stove, Grill and boiler burner are working
I purchase a replacement board (980-102-07) it doesn’t work but show different symptoms. Is the replacement board bad? The symptoms of the new board are
-          Thermostat needle is at zero – good
-          I hear the igniter and the gas ignite – feel the oven getting hot
-          THE OVEN FAN DOESN’T START
-          No blinking lights
  • Tim S.
  • Ian B
Sounds like you have the wrong board installed. Make sure you have the right part number. That isn’t a thermador part number. Model is prg too.
This was a quick search. https://www.appliancepartspros.com/bosch-pc-board-709785-ap5630128.html
this is the only place I could find it and it does show multiple boards. Look for the part number on the old board.
  • 2 weeks later...
Purchased a second board and I have the same symptoms  the oven fans don't come on. So I think the replacement boards are good I have a secondary issue. Any Ideas?
