Maytag MDG508DAW dryer not tumbling
At first I thought it was the typical broken belt.  Got it opened up and belt intact.  Problem was the motor pulley was wobbly and moving independently of motor shaft.  I tried to tighten it and remove it.  I could do neither.  It would not come off.  What to do in this situation aside from installing new motor?  Any help appreciated.
  • MichTech517
  • Vance R
  • AWSHandy
Looks like that the way it comes is a motor with a pulley.
  • 2 weeks later...
Based on your description it sounds like something has broken in the motor. I’ve had this happen once with the shaft internals. All you can do is replace the motor.
