New Appliance Service Manual added: Bosch SHEM3AY55N01 Dishwasher Service Manual
  • 2 years later...
Bosh dish washer model SHEM3AY55N there was an issue with the unit starting after pressing start botton. Thanks to Appliantology service manuals I was able to fix the problem. Issue was solve due to replacing a defective door latch sensor.
Keep in mind that the door latch itself can be in a stuck close position. Sometimes they need to be pulled back into its correct position to work again if it continues to get stuck in position, the door latch will need to be replaced.
