Click here to take the quiz.
Refrigerator Warm?
iridude@aol.com
My freezer is fine but fresh food not running warm. I had a tech come out and I think got scammed he said it was freon low. Now I have refrigerator leaking water and copper coil is frosted. I checked evaporator and condenser fans they both running; I am thinking possibly a defrost issue. However, now did this guy break my fridge for good?
3sncBTBMyVaRtYlM.standard
  • Replies 11
  • iridude@aol.com
    5
  • Vance R
    4
  • Scottekarate
  • worx appliance service
too much freon in system now..
Did he charge the system? It definitely looks like an overcharge.
Also look like he left a temporary access valve on the system. Is there frost on the back wall of the freezer? Model number would help in giving advise.
Edited by Vance R
added request.
iridude@aol.com
Yes, he charged the system and yes its some kind of valve on it and for sure cut a copper line. If he overcharged it anything I can do? Model is a Kenmore 253.78822012
Typically it would be recover all the refrigerant, solder on a permanet access valve and recharge. Replacing the drier would be recommended to do at same time.
iridude@aol.com
I am not sure if the technician knew what he was doing; the fridge is colder now but issue now is water on floor which I think is the reason above.
Yup when the compressor stops running all that ice on the tubing melts.
iridude@aol.com
Yes. Anyway to fix this? Or get a new fridge?
This would be the the fix.
iridude@aol.com
that is out of my league lol.
I would call the tech back let him know what the techs on here told you and see if there is anything he will do to help you out.
