Maytag Centennial MEDC200XW0 Not Heating
Hi,
I'm working on my Mom's Maytag dryer that will not heat.  I have changed the thermal fuse and thermostat but still no change.  Any advice on what to try next would be appreciated.
Thanks!
Kevin
  • KevinO
  • MichTech517
  • Vance R
Start at the terminal block and check to see if you have 240 vac.
Do you have a multimeter? This could be many different issues including any of the thermostats, heating element, motor, board, timer. There are plenty of videos on YouTube that will help you out if you search electric dryer not heating. Like Vance said though make sure you have a good power supply first.
