tex77573 Posted September 14, 2020 Posted September 14, 2020 Manufacturer: GE Type of Appliance: D/W Model Number: GDT695SFL3DS Have you validated the model number at an online parts site like Repair Clinic? (yes or no): yes Have you watched the video on how to search for manuals and have you searched the Downloads section prior to posting this request? (yes or no): yes We have a similar mod # tech sheet but I did not know if it is the same. D/W does not dry and it looks like it may be leaking also. Thanks Boyd
Captain Dunsel Posted September 14, 2020 Posted September 14, 2020 Uses the same Mini Manual as this one. 1
tex77573 Posted September 16, 2020 Author Posted September 16, 2020 Went out today and found leak in a strange place. Heating element shoulder inside of tub broke and made it where you can not tighten nut so it leaked. No heating issue was the thermal fuse was tripped and has a manual reset on it. I reset it and heater worked. I am going to replace heater and thermister that should get it. Thanks Boyd
Dwbingham Posted May 25, 2022 Posted May 25, 2022 I am currently servicing a unit with the same model number requested GDT695SFL3DS it is very similar to the manual provided, but it is slightly different. The doors are dissimilar and I cannot disassemble using the instructions on this sheet. Please help, I am on location!
Dwbingham Posted June 2, 2022 Posted June 2, 2022 Thank you so much for your help with this... big learning curve for me on this job. I didn't even need to take the door apart 1
