Manufacturer: GE
Type of Appliance: D/W
Model Number: GDT695SFL3DS
We have a similar mod # tech sheet but I did not know if it is the same. D/W does not dry and it looks like it may be leaking also.
Thanks Boyd
Uses the same Mini Manual as this one.
Thank you sir
Went out today and found leak in a strange place. Heating element shoulder inside of tub broke and made it where you can not tighten nut so it leaked. No heating issue was the thermal fuse was tripped and has a manual reset on it. I reset it and heater worked. I am going to replace heater and thermister that should get it.
Thanks Boyd
  • 1 year later...
I am currently servicing a unit with the same  model number requested GDT695SFL3DS it is very similar to the manual provided, but it is slightly different. The doors are dissimilar and I cannot disassemble using the instructions on this sheet. Please help, I am on location!
See if this is of any help:
Thank you so much for your help with this... big learning curve for me on this job. I didn't even need to take the door apart 🙃
