LG Washing Machine Not Spinning
LG Model WM3470HWA Washing machine.  Symptoms are electrical smell and will not spin. Water came out the day before but ran a load since then just fine, but when I moved the washer there was a lot of water underneath.
Diagnostic mode shows all things work except low speed spin and high speed spin.
Not sure how to diagnose from here. What could likely problems be?
Thanks!
  • Replies 1
  • OldYeller
  • Vance R
Start by looking for the leak. If it is one of the water valves is leaking it could be leaking down on to the motor. Check the tub bearings for noise and play. Make sure the rotor bolt is tight.  If needed ohm out the stator windings, they should all have the same resistance.  Usual problem items if everything else checks out good are the hall sensor and/ or the wire harness from motor to cabinet.
