Click here to take the quiz.
LG LFX25971SW Refrigerator
I have a 12 year old LG Fridge.  This model has the freezer on the bottom.
The freezer is plenty cold.  Everything is Rock solid and the front door display reads -1.   The door seal freezer and top, look good.
I am getting a leak from somewhere that is causing a sheet of ice to form in the bottom of the freezer and small puddles around the two front feet.
In the past, I have had to replace the water cutoff valve because the incoming water pressure was too high.   I ended up putting a pressure regulator on the incoming water line (along with a new valve) , and that problems was resolved.
I have checked for leakage around the water filter and dont see anything.  I also dont see any leakage around the water dispenser or the icemaker.  In fact, I dont see any sign of water trickling down anywhere.
The temp in the fridge is 38 and not seeing any liquid in the bottom of the fridge.
I check the condensate pan in the bottom back and it is dry.
Thoughts?
  • senoiasummer
  • Vance R
  • Clayton's Appliance Repair
6 minutes ago, senoiasummer said:
Thoughts?
Defrost drain is iced up. Remove evaporator cover and deice drain. Steamer works the best to rpevent damaging the plastic liner.
Make sure the drain tubes are Clean, behind fridge
