Left door won't stay open. Whirlpool WRFA60SMHZ Fridge.
SonofaWhatthe
Hello and thank you for reading.
This fridge has a french door design w/ the freezer drawer on the bottom. The left door opens easily but won't stay open. The right door does everything right. It opens easily, stays open but swings shut without help once you start it back from still.
I'm not sure this is by design and the left door is not SUPPOSED to stay open? I have leveled the fridge and the front wheels are slightly off the ground.
When you look at the tops of the french doors the left door is slightly lower than the right one. I don't see a door adjustment screw on the bottom hinge of this door when I open the fridge.
https://drive.google.com/file/d/1Fw1AgFBPeX42On9ftboBW5Uoul2Y5l8U/view
  • Replies 1
  • SonofaWhatthe
  • Vance R
Check the level front to back. Usually if the door is open all the way it should stay in place and about half way closed is should move in it's own. Most french door refrigerators use need to manually close the door completely. Think the right door hinge in thehole there is a set screw to adjust the height of the door.
