psc25pswass water and ice dispenser gradually freezing up
Lahouse63@gmail.com
model #psc25pswass water and ice dispenser gradually freezing up in door, any ideas?
  • 2 weeks later...
  • Replies 1
  • isaac
  • Lahouse63@gmail.com
First i would check that the ice door is sealing well and not staying open,  if you sure ice door is sealing well i would raise the freezer temperature a little and use the dispenser every single day,  you can try adding insulation padding in the inner door but not real success with that,  good luck
