wfw87hedw1 whirlpool duet washer frontload
The outer boot clamp on my whirlpool front load duet washer (wfw87hedw1) came off recently.  I put the clamp back on but the washer is leaking about a tablespoon of water each load.  Not horrible but enough to be annoying.  We do a lot of laundry with 5 kids.  I have tried removing the clamp and resetting the boot but it still leaks.   It has been a few months now and the clamp has not come off again but the leaking continues.
Any idea what can be done to resolve the leaking issue?
Thank you
Matt
  • matty1stop
  • 16345Ed
You have to closely inspect boot for small rips or tears.
Thank you.  I will do that.  Is there anything you would suggest to repair the tear?  I found a video that repaired a large tear with polyurethane sealant
A “repaired” boot will not stay repaired. It would need replaced.
