Samsung Fridge, #RFG237AABP/XAA - Power Surge - Ice Maker - no water.
RFG237AABP/XAA  Oct. 2012 build
We had a power surge, one of the victims is our Samsung Fridge Ice maker.  It appears that the fridge is not allowing water to enter the tray to freeze.
Where do I start to trouble shoot this?  How can I verify that the solenoid is not opening to allow water to fill the tray?
Thank you in advance.
Cooler
  • Replies 1
  • Olybarn
  • Vance R
Does the water dispenser work?   If yes push the test button on the ice maker to start a harvest cycle.  Measure voltage at ice maker fill valve, toward the end or just after harvest cycle stops there should be 120 vac for about 5 to 8 seconds.  If no check voltage at primary valve when dispenser paddle is pressed, should be 120 vac. If voltage good disconnect out going water line of valve and re-do test with outlet pointing into a glass. If water comes out move down the line to next item - filter or valve - repeat. If no water comes out - check incoming supply line for flow.
