noisey compressor
navtek2
trane condensor unit makes rattle and clatter noise when shuts off. didnt use to make this noise . is it about ready to fail .replaced condensor fan last year. unit is 19yrs old. any ideas?
  • Replies 4
It could be yer compressor rubber mounts are making that noise
they appear to be ok ,no cracking, sounds internal. a buddy says it might be internal springs that suspend assy inside the can. dont know for sure.
  • 3 weeks later...
Some of the old type units utilized a check valve in the high side line that would be the part I would suspect first. The old reciprocating compressors did not back seal well and if the valve where not installed or failed the gas pressure would actually chug the compressor in reverse when it shut down. Shortened the life of many a compressor.
 change compressor rubber mounts , check tube
