Having several problems with my washing machine, not sure if they are related or not:
1) During the spin cycle a small amount of water will leak from underneath the machine, right from where the drain pump is located.  I’ve replaced the drain pump and it seems to stop the leak for a few weeks, but then the leak reappears. I’ve replaced the pump twice now with the same results
2) over time a strong smell of rotten eggs will emulate from the machine, and I noticed that when I disconnect the hoses from the drain pump there is quite a bit of water that comes out, and the smell from the hoses seems to be strong
3) occasionally cold water drips from underneath the back edge of the opening (where the water comes from when the tub fills for a wash cycle).  Most time the drip stops on its own, but will then reappear, sometimes a few months later.
Any help is appreciated!
thanks
  • Replies 1
  • Vance R
  • Seanf1277
For the leak in the drain pump area may need to look closer at the hoses to make sure there is no build up or splits.  For the smell may need to remove the basket to inspect the outside of the basket and the inside of the tub. Clean as needed. The last item is probably an intermittent leak from water valve
