Water leak from icemaker/water dispenser panel: Kenmore Elite model #795.79752.901
aaron fixes at home
Appliance: Kenmore Elite (LG), French Door Refrigerator, Bottom Freezer, water/ice dispenser in left door
Model: 795.79752.901
Year purchased: 2009
Water appears to be leaking from the very bottom of the water/ice dispenser and causing rust buildup. The leak is relatively small, but constant. The water does not flow out but seeps with a drip once every day or two. I have turned off the icemaker, which seems to have stopped the leak. Water dispenser continues to operate as normal.
Are there any common failure points? I am going to disassemble the icemaker tomorrow to check the water supply lines and fittings for leaks. Do I need a detailed diagram or is this straightforward?
Thank you in advance for your help.
Aaron
  • Replies 0
  • aaron fixes at home
