Whirlpool fridge led lights out. Mod#WRS322FDAM04
I have a fridge only 3 years old and I believe the freezer light went out first and they are all out now I’m including 2 in Other compartment. Maybe some light flickering once in awhile. Is there a good chance of the led driver and is there more than one? Need to fix and was going to call whirlpool also because this shouldn’t happen within 2 years.  Would appreciate some input on this.  Thanks so much
You most likely need the led board which is part of the fridge led on fridge celing,  however you might need that freezer led lightbas well,
Thanks.  From what I researched, it’s the top fridge compartment light, like you say, that contains the electronics for the others also. Some companies trying to push buying the 3 -pack of lights, but I guess most of the time, just changing the one in the ceiling fixes them. And one tutorial says to remove that fixture and warm it up with a hair dryer or Maybe a heat gun and it has been know to fix them also. Terrible design for sure, and not right.  Would rather have the old incandescent bulbs if this is what to expect.
Agree 100%
  • 2 weeks later...
Fixed one of these yesterday with the same issues. The freezer light was out as well as the lights on top of the fridge compartment. All the side lights worked fine. The freezer LED was bad. Swapped it out and problem solved. That board is pretty expensive.
Thanks.   On this model the freezer light and the lower fridge light are less than half as expensive as the top fridge light that has the electronics and Led driver.  Still haven’t replaced it yet, but soon I think.
  • 1 year later...
Thanks for the great info guys! Helped speed up a call that had multiple issues. Led board gets 120 in but only about 9v dc out. I heated it up then got closer to 37 v and the lights came on fine 👌. Still going to replace it.
