Please help lte6234dq2 thin twin combos dryer issue
Lyricalsalvation444
I'm working on a lte6234dq2 whirlpool thin twin washer/dryer combo..I replaced the dryer motor and replaced the motor wiring harness plug with individual female terminals. I took apart and cleaned the dryer timer contacts..reconnected the wires and now when I turn the timer knob to automatic delicate setting and press the push to start/end of cycle signal button it starts and heats up fine and advances through the cycle as it should.. when I turn the timer knob to any other cycle and press the push to start knob it does nothing at all if I have the knob turned in the buzzer off position..if the know is turned in the buzzer on position it just buzzes when I press the button and stops when I release..although i can hear the timer motor running...please help..any Yelp is much appreciated.
  • Lyricalsalvation444
    4
Lyricalsalvation444
Also I am trying to add photos to this from my gallery in my phone and I'm not sure how to do that because it asks for an image url and I dont know what to do
Lyricalsalvation444
Do I have a wire out of place?
Lyricalsalvation444
Anyone have any idea?
