lte6234dq2 thin twin combos dryer issue
Lyricalsalvation444
Really need some help..I have a thin twin and replaced the motor and cleaned the timer.. hooked everything back up and it heats but it only runs on air dry..all other settings do nothing when you push the start button..if u have the start button turned to the on position for the end of the cycle button then it buzzes every time you push the start button and quits buzzing when u let go and the dryer does nothing..could I have possibly put a wire back in the wrong place? Please help..
  • Replies 4
  • Lyricalsalvation444
  • 16345Ed
It heats on air dry?
Lyricalsalvation444
It just only runs on air dry..no other selections on the timer start when the push button start is pressed ..I replaced the motor which was a 279811 motor with a 3391892..which has a different setup on the motor switch..I matched up the wires with the terminal numbers so it should have worked fine..whirlpool replaced motor 3391892 with 279811
Lyricalsalvation444
Wish I could post pictures from my gallery but I cant figure out how..it asks for an image url
Wrong motor you need the 279811.
