Dryer shuts off before clothes dry
Lyricalsalvation444
Dryer shuts off before clothes are dry all the way..theres no lint obstructions so I have good air flow and the moisture sensor is working as it should..anything else that would cause this? It's a kenmore 417.61722510 stackable.
  • Replies 6
  • 16345Ed
  • Lyricalsalvation444
  • isaac
Did you actually disconnect vent at back of dryer and run a load?
on electric dryers your symptoms are highly likely caused by air restriction.
Lyricalsalvation444
Yes theres no air restrictions
Try timed dry for 60 minutes,  is it drying?  Is there heat?  Is there heat 30 minutes into the cycle?
Lol, why doesn’t anyone actually answer my question when I ask this?
The question is did you run a load with vent disconnected?
im not asking if you think there are restrictions
  • 3 weeks later...
Lyricalsalvation444
Im sorry yes i did..i checked all areas inside the machine where there would be an air restriction and it does not have the vent connected either
