Hello
Washing machine drum stopped spinning even in the spin cycle mode, machine does fill in and empty but does not spin the drum (only initial few seconds)
I done some initial checks:
  • Drivebelt is not worn
  • The drum rotates fine
  • Have not inspected bearings but would expect it would make grinding noise and wont rotate well
  • The motor brushes are ok and seem to be in contact with the armature motor
  • Motor does work as it starts the initial spin
  • Weights are not loose
  • Front door does lock and unlock as it should
  • I checked level with spirit level and that in the centre
https://www.indesit.co.uk/i/indesit-ecotime-iwdc-6125-washer-dryer-in-white/f062505
Any idea please? is it the control module/pcb?
Thank you
  • Replies 0
  • vadimo
