Just a couple of quick questions regarding fill and fill times.
1. Am I correct in assuming that this dishwasher has a timed fill period?  Or is it perhaps level based. From what I have manually timed, it appears to be very close to two minutes. I presume the float is only a safety mechanism to prevent any overfill situations
2. What should the proper/correct water level be immediately after a fill cycle?
I recently had some plumbing work done with the DHW supply line and the plumber didn't purge the DHW line properly when he was done. I realized this after I found sediment in my bathroom faucet shortly after he left. I DID purge it correctly at that point.  I am pretty sure the dishwasher wasn't run prior to me flushing the DHW line.   But I don't want to pull the dishwasher out unless I have good reason too.
Thank you.
  • Replies 4
  • pjw73nh
  • isaac
Most new kitchenaids are timed filled,  it really hard to determine the height but useally just bellow or at the heater level
I probably should've mentioned the age.  The dishwasher is about 20 years old. (In perfect working order).
Is it washing well?
The old units the water the water gets to the center of heater if i remember correctly
Yes, it seems to be washing just fine.  I was just curious about the water fill "flow chart" no pun intended.
