Thermador 36" Gas Range Broiler Repair
Folks, I have a 2005 model Thermador PRG366US/01 36" gas range.  Recently the gas broiler stopped working.  The oven works fine.  The broiler glow ignitor did glow but after some research I figured the ignitor might be weak and not letting the gas safety valve open.  So I purchased a generic glow ignitor, installed it and it still didn't work.  Thinking that the generic ignitor wasn't passing enough current, I purchased the correct OEM Bosch ignitor.  Again, although it did glow strongly, the broiler still wouldn't come on.  I'm suspecting the dual gas safety valve now.  Two questions:  (1) Does this sound right?  (2) Does anyone know where it is located?  I've taken the burner bases off before to replace the Spark Module, replaced a burner gas valve and ignitor and replaced the oven glow ignitor so I am pretty comfortable working around the range.  Any assistance would be appreciated.
  • Replies 1
  • isaac
  • CAPTBob46
It possible its the gas valve but usually it would test open and the igniter glow,  but guess everything is possible,
Gas valve should be in the rear,
