Hi out there everyone. Have a me more fridge/ freezer model # 106-.53644300 that just stop cooling. Cleaned coils & vacuum ,can see fan running but seem that compressor not working ,placed Hand on it no vibration or nothing. Looked at flowchart says check compressor relay.being a fresh your grasshopper I ask how master. Are there anyone that can led me on the path of repair?? Everything else seems to be working.
  • Replies 4
  • Popdaddy
  • MrApplianceMatt
  • isaac
  • oleredtruck
You'll need to check the compressor windings with a multimeter for resistances. Does the compressor try to start at all?
No start. Have unplugged 3 times hoping for reset no luck. Made some calls for service but everyone telling me two week’s earliest.by then wife will take card and buy new. Help needed soon .see wires plug go to compressor.what should I look for to test? Color code of wires are 2 whites, Green/white strip, and pink. With meter hat should I see. Or jump to test compressor? Thanks for any help anyone can give me
Not sure what tools you have but you will need a live meter and a multimeter,  are you hearing any clicks every few minutes?
  • 3 months later...
Not sure if I am posting correctly. We have a Kenmore 596.75509400. It is clicking intermittently. At times the freezer has gotten above 25 degrees. When we unplug it for a reset for an hour or longer it seems to work fine for a few days them starts clicking more often as time passes. We are unable to get an overload relay part because of supply constraints. We are wondering if it is possible it is the overload relay switch. We had someone say that normally when the switch goes bad the compressor just will not come on. Our compressor does come on and purrs like a kitten most of the time. We put a cheap part from Amazon on and it made the clicking worse so put original relay back on. The fridge is cooling fine. The ice maker is working normally as well.
