GE Dryer Won't stay running. DCC***0GD3WC
Tried to post a pic of the obscured model number.  Here is a Link.
Dryer will not stay on.  Its a coin op GE gas dryer.  If I hold the button the dryer will run and heat up.  Is there a sensor or kill switch that I need to replace?
Arigato
  • Replies 5
  • Tsuriman
    4
  • 16345Ed
  • isaac
Sorry, Serial number GM718993
Sound like you may have a bad belt switch
Thanks.  That thought also led me to a faulty door switch or prong.  I will check that as well.
Went to check on it and realized the drum is not spinning.  So I am guessing the belt.
Probably simple broken belt.
