LG WM3575CW Washer: LE Error: which replacement part? Hall sensor alone or entire stator assembly?
Hello new friends.
Like many out there, my LG washer threw an LE error recently. I read the articles and learned that most likely I needed a new hall sensor and that the part # should be 6501KW2002A. I purchased one here: https://www.amazon.com/gp/product/B078GJFXKH/ref=ask_ql_qh_dp_hza
I installed it and it didn't work: I still get the LE error.
So I attempted a more fine-grained search for a  hall sensor that will work with my washer. After looking at RepairClinic, AppliancePartsPros, SearsPartsDirect, and several other sites, I have yet to find a hall sensor that, according to those sites' compatibility checker tools, will work with my washer.
My question 1: is there a hall sensor out there that will work with this washer? if I did in fact buy the wrong one, and there's a right one out there will fix the washer, that seems to be the cheapest and easiest fix.
But there's more. Searching RepairClinic, it appears that there is a compatible sensor, but it's attached to the entire stator assembly and the whole thing is selling for $170 (https://www.repairclinic.com/PartDetail/Stator-Assembly/4417EA1002Y/2649230). I'm fine paying that (still cheaper than a repair call) but for the money I wanted to be absolutely sure it's the right part. So I fired up the chat function and chatted with Diana, who was very nice. She introduced a wrinkle: apparently there's a WM3575CW/00 and a WM3575CW/01. The /01 model has a different, less expensive stator assembly (https://www.repairclinic.com/PartDetail/Stator-Assembly/AJB73816004/4117201). But my product label doesn't have a slash and either a 00 or 01 after the model number.
My question 2: can I assume that if my model number doesn't have the /01, then it's the /00 model and the 4417EA1002Y stator is correct?
My question 3: is there something else I'm missing? (likeliest answer is yes)
Thanks!
  • Replies 1
  • nkane
In the end, it was Question 3.
Further reading led me to some comments from folks that found broken wires in the wire harness. So I thought I might go back in and have a look. I opened up the back of the machine again... and found that I had somehow connected the wire harness upside down! So I fixed that, put everything back together, and it seems to work! Ran a test mode cycle and two laundry loads with no LE code.
So there you have it: a random Amazon part plus not messing up equals a fixed washer.
