Maytag MDB7600AWW will not complete wash cycle
The washer will run several loads correctly, but recently it has stopped midway thru the cycle and just stops...all lights off...water in washer.  It is stopping just after the wash cycle and not proceeding to the rinse (or anything else).  this has happened several times, then it will complete cycles correctly for a few days then happens again.  I'm guessing it may be a the control board going bad?
2 hours ago, JS239 said:
water in washer.
Could be pump going bad...?
It seems that the cycle stops.  When i restart using light was it seems to function normally....????
When you restart using the light load cycle it operate normally?
Not really, it runs the wash cycle and does not rinse,  just pumps the water out after washing and stops...that way i'm thinking it may be the circuit board.
Have you tried running it on other cycles?
It just completed a wash on the normal cycle and worked perfectly.  Seems to only occur from time to time.
If it is the board , it is only available  if the serial number starts with 19 or larger . Try cutting power to the machine overnight and see if it works right when you power it back up
