Water drip from door of LG LDS5040ST dishwasher
Good afternoon!
I was able to install the sump assembly without a problem and the dishwasher functions better than ever.  I do have a drip from the bottom of the door that I didn’t have before.  I double checked the level and it all seems ok to me.  I checked the seal and wiped it down just to make sure but the drip still persists.
According to LG the water level should be between the two step downs in the bottom of the dishwasher.  It looks like the water is a bit more towards the upper one which could be the source of the problem.  I suppose raising the front of  the tub would keep the water away from the door bottom but then it would be out of level from front to back.
Can anybody offer any thoughts on what I should check or do?
Thanks in advance for any and all help!!
Jeff
  • Replies 1
  • jeffg
It seems to be dripping out of both corners of the door.  I did look at the gasket again and there a couple spots that could be questionable.
