Manufacturer: Kenmore
Type of Appliance: Front Load Washer
Model Number: 110-45081400
I need the error codes and Fast Trac  for a front load kenmore washer. The customer doesn't have the manuals nor any other paper work that came with the machine. The only source of information is the error code F 06. The customer says it will not spin nor agitate. Original call was for shaking and lots of vibration. Changed all 4 shocks then the customer brought up the no spin agitate problem.With no error codes explanation nor manual . Stuck and need help. Thank you very much.
  • Captain Dunsel
  • oldtrooper74
Uses the same one as this!
Thank you sir for your information. From the customers info and the repair work on shocks it seems to go back to the vibration has loosened some or one connection. Have to return and check all connections on the mcu. Thank you again so much for pointing me in right direction. Oldtrooper74.
Your welcome!
