LG Direct Drive Washing Machine - Fills - Does not Agitate - Spin.
William Gates
I have an LG Direct Drive Washing Machine - Model WT1101CW built 7/2014.
1) If I select a Spin cycle... the washing machine completed the spin cycle.
2) If I select Rinse and Spin...  the washing machine (at normal speed) takes forever to fill.
After 5 to 10 minutes (of constant filling at normal speed)... the machine stops filling and and displays a 1E error code.
3) If I do a speed wash or regular wash... See #2.
I've replaced the LG 6501EA1001R Switch Assembly... no difference.
https://www.amazon.com/gp/product/B077N6Y8Y4/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
I can hear the pump removing water.
I have cleaned all the water inlet / filters.
I have clean the water exit hole.
Open to suggestions ? Thanks in advance... I do appreciate it.
  • ABA Tech
  • isaac
  • William Gates
Mighy need a new water valve,  is there a good water flow into unit? Does it fail only in rinse?  When you do a normal cycle what portion of the cycle it fails,  do you have well water?
1E means slow fill, I'd start with a new fill valve and possibly new fill hoses as well while you're at it. Flush the shutoff valves for a while before reconnecting the hoses to the new fill valve to make sure there's not a bunch of minerals floating about.
