Manufacturer: Frigidaire
Type of Appliance: Wall Oven
Model Number: RBE-34P
I just want to say if you find this one....that will be impressive
Tech Sheet/Service Manual
If it exist
Please
Thx
Moe
  • Replies 7
  • bigmoe_725
    4
  • Budget Appliance Repair
  • Son of Samurai
  • Terry Carmen
Wow, that's an oldie. I've got nothing -- how 'bout any of you other Brethren?
You might need to contact electrolux and see if they have anything on microfilm or paper that they could copy and send you.
I tried my best google-fu and came up with nothing.
Are you sure the model number is correct?
Somewhat basic unit, (it does have self-clean to complicate it slightly).
You may have to just wing it or decline the repair if you're not comfortable with it.
There is a very good chance you will find the schematic/wiring diagram glued to one of the sides or possible in an envelope in the control compartment, (very common for the diagrams to be glued on the side or back of the old Frigidaire ranges/ovens).
Im taking the call tomorrow, it is a home warranty repair. And i hoping that the wiring diagram is glued somewhere in the compartment. The other problem is not website seems to have the parts for this old girl.
Thanks for all yall help...
That's going to be your biggest problem if it is anything other then a bad element and even depending on the style of elements that might even be a problem, (lots of the older Frigidaire's had plug in elements and it has been pretty difficult to find the female receptacle contacts if they are bad).
Maybe you will lucky and neither element is working and it ends up being the clock not being set correctly for "MANUAL Cook".  It looks like the third dial under the clock is set to MANUAL, which I'm pretty sure that is the only thing that has to be set to for manual cooking.
