Manufacturer: Frigidaire
Type of Appliance: Range
Model Number: Plcs389ecc
I downloaded the schematic but it’s throwing an f20 error code after getting a board repaired from core centric for a bad bake relay. There is no error codes on schematic or paperwork that was in oven.
  • Westendappliance
  • EthanRanft
From the tech sheet:
(F20) Control has detected a problem with the communications link with the electronic surface element control (ESEC -some models).
1. Check connection between P4 on EOC and P7 on left front ESEC board.
2. Replace the EOC and/or left front ESEC board.
I say check the connection but then report it back to Core Centric and have them fix it again for free
Thanks. Looks like I’ll be sending it back.
