Manufacturer: LG
Type of Appliance: Top load Washer
Model Number: WT7300cw
Found a similar manual, but not for this one.
thanks.
The manual MFL69647002 for this modle is here, but listed the model as WT7200c. There is a newer version of the manual and i can upload if needed:
Hey thanks for the manual, if you could upload the newer one that would be awesome.
the buttons on the machine I’m working on seem to be slightly different, so I’m wondering if the service mode might be slightly different.
Also, the front of the control panel I’m working on seems to have hidden screws that you need to remove in order to the get the front of the control panel off of the top panel, unless it was just clicked in hard.
Thanks again.
Uploaded newer version pending approval:
  • Like 2
Thanks brotha.
