Manufacturer: Viking
Type of Appliance: Gas double oven 60” range
Model Number: VGCC5606Gsslp
Need tech sheet for this Viking Range.. the left oven and griddle will not spark at all . The right oven and all the too burners work perfectly.  I think the DSI module is bad but just curious about  both modules being  bad. Or if it’s something in common with them both
Edited by Jessematthew
  • Replies 5
  • Jessematthew
    4
  • Terry Carmen
Are you sure about the model number? I can't find anything on that anywhere.
I’m pretty sure  I know I’m having trouble finding it too. VDSC560-6G is on the owners manual and I can’t find anything on it either
That's a real model number. The service manual is here in the files section.
The griddle has it's own board that controls the ignitor spark and gas valve and temperature. The ovens are apparently electric if the service manual/model number is correct, and each oven has it's own control board.
I'd probably start by looking at the wiring where the power supply cable or line cord is attached. The oven and griddle don't seem to share much else.
It’s all gas even the oven , I appreciate the help I’ve had trouble finding the correct wiring diagram but I will trace  the wiring out.. I ordered  a DSI module so I will no more  next week ..
thank you
  • 3 weeks later...
Problem was both of the dsi modules thanks
