Maytag MFC2062FEZ01 fridge - Items in fridge are freezing
Hi,
3.5 year old Maytag fridge.  Replaced a bad control board about 6 months ago.  Items in fridge have recently started freezing.  I increased the fridge temp from 38 to 40 but still freezing.  What are the most common causes I should check and/or clean first?  Thanks in advance for any advice!
  • vaccine
  • 16345Ed
Posted Images
2 hours ago, vaccine said:
Hi,
Part 15. Damper. May not be closing.
Thanks, will check the damper.
  • 1 month later...
So I checked the damper and it was not closed.  I replaced the damper and it seemed to work fine for a week.  Then it started happening again.  I checked the new damper and it's closed.  Could it be the control board I replaced?
