Problems with Cabrio WTW7300DW0
I have the field service manual for this washer, have had intermittent problems with the unit, select wash mode, press start, then it sits there making a bunch of noise, the center moves and the ratcheting noise continues, after a few minutes, it shuts off and the lid unlocks.
Here are the instructions:
2. Select any three (3) buttons (except
POWER) and follow the steps below, using
the same buttons (remember the buttons and
the order that the buttons were pressed):
Within 8 seconds,
• Press and Release the 1st selected button,
• Press and Release the 2nd selected button,
• Press and Release the 3rd selected button;
• Repeat this 3 button sequence 2 more times.
My question, is there are only touch buttons on the unit, which ones should I use?
  • PalmettoJoe
Figured it out, retrieved error codes, F8E3 overflow, F0E3 overload, F0E5 Off Balance, F2E1 Stuck button, F6E2 Communications Error, F2E0 loss of power.
Any thoughts on what you see here?
Within 8 seconds,
Pick any three, just remember first, second and third button choosen, otherwise you will not be able to do more diagnostics.  if so, hit power button, and start again.
