Maytag Washer LA412 how to test motor and Exte switch
My 94 year old mother has had this machine since late 60's.  It was last serviced in 1973 by my 95 year old dad (he can't remember - damn Dementia) when it received new belts, a new OEM motor and Exte switch and motor mount assembly, new suspension springs.  A few days ago she called to say that she was smelling an acrid smell and turned it off.
I picked up a set of belts and drove over.  I unplugged the power, drained all the water out, and replaced the belts.  Turned the rotary switch to the off position and plugged the machine back in.  I set to small load, rotated the switch to 2 minutes, and turned on.  The machine loaded water (no clothes) and started cycling.  After a few minutes it went into drain cycle and pumped all water out.  It then filled with water again and when that cycle started I could sense the acrid smell coming from the motor.  The motor was also very hot to the touch - I couldn't hold my hand on it.
I turned it off and rotated the switch to where it should have started draining the water again (between the rinse & spin I reckon). I turned on and nothing happened but I could sense the acrid smell again.  I'm ready to buy a new motor but I have some concerns about whether the motor is the problem or if it is being overloaded and I would have the same problem with a new motor.  I think the water pump is OK because I can turn it by hand and it did pump the water out the first time and I didn't sense any belt slip during that time.  Water pumps aren't too expensive so I would replace it if experts on this forum think it may be a problem.  What else can I do, what else can I check prior to spending ~$200 for a new OEM motor?  I'm comfortable doing electrical checks (with my Fluke) if I knew what terminals to probe on the Motor Exte switch.  I'm also comfortable applying 120V direct to the motor if I knew which leads to contact in order to check either (or both) directions.  I've spent hours on the internet trying to find wiring diagram or diagnostic diagram with no luck.  Other than this problem the machine is still in excellent condition and my mom really doesn't want to learn how to drive a new one.  Can anyone out there on the forum provide some helpful material, trouble shooting steps, etc to help me confirm that a new motor is the answer?  I'd sure like to be able to test the Motor Ext switch if someone can tell me which connections to probe.
Thanks everyone and to all a happy and healthy New Year.
  • Replies 4
  • evaappliance
  • naftaturbo
Posted Images
Your washer shows to be a single speed , the best test for the motor is to make up a test cord out of an old or cheap extension cord . With the belts off make sure the transmission pulley turns counter clockwise without much effort. If it does you most likely will be dealing with a bad motor.
I would see if I could find a good used one , in my opinion a older used motor will last longer than a new one built in today’s world.
Thank you evaappliance, that's really helpful.  I'll make up a test cord today.  Silly question, but is that counterclockwise looking down from the top of machine or looking up from bottom of machine?  Would it make sense to make an adapter so I can turn it with a beam-type torque wrench?  What torque would I be looking for as maximum acceptable?  Thanks again!
Looking from the bottom up,    you will not need a wrench, it should turn with  little more than Using one finger on a empty tub.   If you have to turn it with much more force than that the transmission is locking up
